S6/S6 Edge battery drain culprit - Mobile Radio Active.
John Woo1
278
Its a longtime known bug with lollipop since it released and Google havent care to fix this bug yet. So its not the devices that to blame and happens to all devices that running lollipop.
This will explain: https://code.google.com/p/android/issues/detail?id=165558&sort=-stars&colspec=ID%20Type%20Status%20Owner%20Summary%20Stars
Read about it and put a star on it (top left side, Issue 165558. It will turn yellow after marked it). The more people doing it and maybe finally Google really care to fix this longtime battery drain bug on lollipop.
Short explanation:
Its about Mobile Radio Active, some "bad" apps would keep mobile data active even its closed or not even started. It would stay at background, keeping mobile data active and it would drains the battery fast.
Is that why Cell Standby is now on the top of the list under battery usage??
Brandon
Samsung Galaxy S6 edge
RangelS25
