S7 connection problems - Verizon
DCDSports
15
Hello. Having some issues with my Galaxy S7 consistantly dropping wifi coverage. I'll be connected, then it will drop, and then be unable to find an IP address. It's not just at home . . . it's everywhere I go. It's very frustrating, and kills my battery and data.
Any thoughts?
Doug
Try installing Wifi Analyzer from the playstore to check your signal level. Might be your radio is weak, or you might have installed an app that's interfering with your connection. You could also start your phone in Safe mode to see if the problem persists.
