s7 edge 7.0 beta thread
Yep, I just went and checked the thread where I thought I'd seen it and the first Sprint post was from 2:45 AM ET on the 10th. So, I guess it's true unless he's on the West Coast. ;)
I think that was me. I got my beta update on the 9th. I'm in California.
So how long do the rest of us have to wait for this to become available fully? I was trying to register several times and always got the error. Then a message saying that they were maxed limit. It's totally stupid.
Just worried it can cause issues since it's not available for download as an official update. You guys aren't concerned?
Well it is a beta, hence being pushed by samsung to try and get any bugs ironed out before the full release.
Mid to late December according to the beta notes. It's not that long really. I got it on o2 in the UK yesterday. But believe me it's worth the wait. I had to give up my note 7 for an s7 edge. Now my edge feels as good if not better than note 7. It's a mega update. You will not be disappointed.
So I have the beta and when I go into the beta app I don't have any options to send feedback. Anyone else having this issue?
There should be an app on your phone now called "Samsung Members". This is where you can send your feedback among other things.
I couldn't get Good Lock to work at all. You can edit the notification area though. If you fully expand it there's 3 dots beside the settings gear icon top-right that will let you move then around.
I have Sprint version and cant find the data toggle anywhere
does anyone know if there is a setting for lockscreen that you can have notifications as icons on my note 7 you had that option
Has Samsung changed screen sensitivity settings? I found the S7 to be too sensitive but the Note 7 was perfect.
I'm loving the update so far, its taking a while to get used to the new settings menu but I'm sure it'll become easier soon. Has anyone used android pay yet? I tried this morning in my usual shop before work and it wasn't picked up at all by the card reader. I've checked the pay app and all the settings I can think of and they all look correct.
Also the out and about feature is gone? I really liked this for setting things like mute and WiFi off at work, wifi on when I got home. Was this a feature on the note? I'd really like to have it back.
Out and About feature....
I've not seen that setting on my s7 edge?
Anyone got facebook working after doing a factory reset? It worked ok when I updated to nougat but after a factory reset and fresh install of apps it just force closes now and won't open at all
I did a factory reset and Facebook is working without issue.
I think most of us are "disappointed" because we couldn't get on the Beta train and are reading how great this update is. Coming from the Note7, I'm sure it's a huge improvement in the S7E to close the gap. The fact that the Beta program was so limited in its participation and this information was not known at the onset is the irritating part.
One question on the update...did they find a way to incorporate gif maker without the s-pen?
Interesting. Does your version come with facebook already installed or did you install it from the play store?
Anyway if it happens to anyone else I found the solution in the beta feedback forum. You have to go into settings and accounts on the phone and add the facebook account there, before opening the facebook app for the first time. Then it works fine
oval_clarity
