S7 Edge AUX issues
I too had the prob... Found the solution.... The problem is not with the aux cable or stereo... It's with the music player...use the default Google music player else any other player.... I changed from jet audio to rocket player... Works perfect for me...
i found a solution. Go to settings, sounds, sound quality, connect your aux and enable uhq upscalerposted via the android central app
you the [language redacted by Mod] mayne bro.. It works like karate. Sound smoother than butter.. Straight g for this... Good lookin brahdah..
I'm getting allot of noise/static when connected to my car stereo via AUX cable. I didn't have this issue with my S6. Any solutions?
Edit: Tried two S7 Edges and two different AUX cables. Still the same.
I figured it out while your auxiliary cord is in you have to go to sounds and vibration. After that you select sound quality and effects at the bottom then you go all the way to the bottom and turn on uhq upscaler.
dnszola
