S7 Edge- Battery less than 70% Phone lags from sleep
Rande_Raines
Hi,
S7 Edge
Android 6.0.1
When battery level is on 70% or less when I try open phone from sleep either Home Button or power button on the right there is a 5 second lag. I am avoiding a factory reset due to apps/data etc.
Any ideas?
I have so far cleared Cache and removed SD Card to make sure they are ok and no difference.
Cheers
Rob
Restart into recovery mode (usually Volume Up/Home/Power) and clear the cache there too. (It's a different cache.)
boone
