S7 edge Battery life
Is there a main battery drainer within android system that can be disabled with package disabler or is it a case of disabling lots of things which all add together to improve things?
It's not the battery on my S7 Edge, it's Cell Standby and some problem with Google's Android system and they must sort this as a priority.
My phone has gone from 100% last night to 75% now (13 hours later) without having used it once. No calls, no texts, no browsing, no games, no music played. It's sat there doing nothing but eat battery.
My Nexus 4 in comparison loses about 4% in the same time period.
Google, sort it.
Google, sort it.
Or it could be your carrier who should sort it (they won't). I've had two updates since I got the phone last April and battery life hasn't been affected, so if you're using a phone with carrier modified software....
I'm on a sim free version and have had 2 updates since I've had the phone. Battery life has got much worse, mainly due to android system drain I think. So as far as I'm concerned, the updates have made battery life worse!
This is a sim free phone. As is the Nexus 4 with the same company (EE). On the same deal with each sim card.
Cell Standby doesn't even show up on the Nexus 4 battery usage list.
Google, sort it.
What is the Baseband on your EE branded Galaxy S7 Edge?
What is the Baseband on your unbranded Nexus 4 phone?
I don't have a branded phone. They are both sim free. How do I see what each baseband is?
Edge 7 - g935fxxu1apd1
Nexus 4 - m9615a-cefwmazm-2.0.1701.07
Wow. High screen on time for only the second ever charge
Not an unreasonable SoT considering you didn't turn on the mobile network.
my battery suffered with the latest google now update, google play services drain has been really high
so what are you getting on average now for a full charge?
Right now on Sprint's April PD3 update, I'm getting about 4.5 to 5.5 hrs of SOT. Before, on the original Feb firmware, I was getting almost exynos-level SOT of 6.5 to 7 hrs SOT.
Google, sort it.
Package disabler pro solved the problem by disabling many many services. Not easy to use but no better choice
Adekanmbi
