S7 shows charged percentage even with BATTERY REMOVED, ignores the battery
  • Start date Start date
A
Android Central Question
Samsung Galaxy S7 owner here. At some point, the original battery got bloated, so I decided to replace it. After the replacement, with the new battery, the phone wouldn't charge and would turn off after as soon as I removed the charging cable. Charging percentage would show a random constant number (the favourite was between 57 and 60 but could vary).
So I took the new battery off and plugged the charger in without a battery attached. And guess what? The phone shows a random charged percentage (this time fav range is 35-40%).
Tried hard resetting, pressing the power button to drain the capacitors, clearing the cache, nothing helped so far. I am clueless where that number could come from and I am guessing that when the battery is hooked on, the phone doesn't even recognise it.
Any help appreciated!
:confused: Don't get it what you talk about.? : I'm the owner of a Sam_Gs7 and as far as I know
these Phones were built, with Unremovable battery.. So to explain how you manage
to replace the battery - Repost the question or create an account in ACentral
then you may get some help to fix this lower battery percentage
Galaxy S7 battery is not "unremovable", it is fixed by glue and screws. There are plenty of tutorials and demos on how to remove/replace S7 battery on Youtube.
Are you the original OP who asked this question.? if so I assumed you Sign Up
on AC aren't you, well done. Now I post again to apologize for my last reply
But judging for what's been said in the Internet,.These phones comes with
irremovable batteries, but if there's a way to do so welcome. Weird 'cause this
article says No - Link: https://www.samsunggeeks.com/2017/01/14/why-don't-samsung-phones-have-removable-batteries
piikea
