Samsung Galaxy Note 6
Your eyes probably can't tell the difference between 4 k and QHD on a device that small.
In the event that the external SD card returns to the Note 6, I hope that Samsung solves the external SD card problem that is happening with S7.
http://forums.androidcentral.com/sa...rd-notification-keeps-popping-up-help-20.html
I also hope that internal SD card has a 64GB minimum option. 32GB internal is actaully ~ 20-21GB after removing the capacity consumed by the OS.
It's not an internal SD card, it's just internal storage. Flash memory. Other than that, I'm sure Samsung would have figured out and solved the issue well before the release of the Note 6. Sometimes 32gb internal storage is enough, my wife for example doesn't need so much. She has the s7 with 32gb. She most likely won't fill it up and if she does, we'll just buy an SD card. The premium that manufacturers charge for more internal memory is ridiculous. SD cards are far cheaper.
I'd love to get some new features and see some old ones come back mainly:
  • SD Card
  • Waterproofing
  • USB C
  • QC 3.0
  • Please please please bring back the IR blaster!
  • 6GB Ram
Bet yer note 4, don't have a fast charger.
If they make the note 6 with a 4000ah battery like we've heard. That is a nice size battery.
And the newer phones has Lithium Ion batteries.
Don't think the note 4 came with a Lithium Ion battery.
Big difference.
With everything that you get with the new phones like processor speed, ram, better camera and all
Hard to believe it don't outweigh some things you don't get.
1. The note 4 was one of the first phones to have fast charging!
2. All smart phones have lithium Ion batteries. You can't run the more sensitive hardware of smartphones on Ni-cad. Check out the original galaxy phone specs if you don't believe me.
Samsung Vibrant - Full phone specifications
Was a huge fan of Samsung phones, then blindly upgraded from a Note 3 to the Note 6 Edge and have been dissapointed ever since. Really liked the idea of an edge that enabled one touch apps... but soon learned that went away and this one you had to "slide the side" (like my Note 3) to see more apps. Also eliminated the SD Card and IR Blaster (apparently I'm one of the few that found the IR Blaster incredibly useful).
Soooo, I really really hope they bring back the IR blaster (and it seems like a forgone conclusion that the SD card will be back, so that's good).
-Dustin
uobuob
