Samsung Galaxy S10 Tips & Tricks
The Note 10 plus will have a mother of pearl back, 5000mA battery, 24GB of RAM and 2TB of storage. Carbon fiber stylus with twin cameras and a dual quad DAC.
Ok here's my CC lol
I dont need 24gb ram happy with 8 and dont need storage that high just 128gb
But internal write speed 3.0 might be something over current 2.1
You think ?
I think it make things more snappier , its already fast phone because of its specs ..love the SD855 7nm processor
Where are we that we need things instantly? Has the world gone mad? I think I need a pill to slow things down.
Here's one tip I have. The S10 can be used to wireless charge other devices (like wireless earbuds, other smartphones, etc). I can also charge my Samsung Gear Sport smartwatch with my S10. So in a pinch I can plug my phone into a wired charger then lay my Gear Sport on the back of my S10 to charge it at the same time. Seems like a great application if you forget your Gear Sport charger while on a trip or if you need to charge your watch while at the office, etc.
I have 2 more tips can work also on any Samsung with pie
You can make your flash light more brighter by going in notification panel tap on the words flash light not the icon and increase it to 5
The other is same place , brightness slider is at the bottom of the the notification and if you want quick adjustment you need to pull it all the way down , now you can put it above your notification panel and pull the notification little down to adjust
Another tip to share , I'm sure we all know about it but forget.
in settings the search bar you can type in anything you looking for in the phone. it's nice to have this option for quick access instead of going through menu's.
I use this all the time... I hardly ever remember what submenu a setting is in.
I turn it on, but it keeps turning off. Is there another setting?
SOUNDS AND VIBRATION -> ADVANCED SOUND SETTINGS -> SOUND QUALITY AND EFFECTS -> DOLBY ATMOS (AUTO)
As far as I know, there is only one place to enable it.
DanishDanuu
