Samsung Galaxy S3 I9300 - Msg "Unfortunately, the process com.google.process.gapps has stopped"
Re: Msg "Unfortunately, the process com.google.process.gapps has stopped"
Hi everyone ols help me! I have a galaxy note gt n7000 and have a simikar problem but i am not even able to do as stevie says because the phone goes off after like 10 seconds after ivr put it on. Apart from the msg mentioned in above posts i also get simikar msgs about other apps lije samsung, yahoo mail, google play and other. All im interested is getting back the data off the phone if this canjot he fixed, tried getting data from my google acc but all i managaed to get is my contact list and i am desperate for my msgs, pics and my diary :( pkease anyone help. I cannot do anything from the actual device as it wont let me cos like i said it only lasts about 10 secs b4 it switches off agai . Very unhappy and disappointed with it :(( any help would be greatly appreciated xx
You genius! It worked! Thanks Steve!
I have galaxy s3 and i done this what u written thanxs dude i got my prob solved god bless u
- - - Updated - - -
I have galaxy s3 and i done this what u written thanxs dude i got my prob solved god bless u saptarshi chatterjee
My phone the samsung galaxy 3 every time I go to download a app or update it says "google. process has stoped what do I do now please help!!!!:'(
Hi Folks,
I've got this message poping up all the time now, along with Unfortunately, Google Play services has stopped. My phone has also stopped sending messages, it receives messages and calls, though they may be delayed.
I've tried;
*removing then re-adding my google account
*app manager, reset app preferences
*app manager, all, download manager/google play/google play services clear cache/data
* i then read somewhere it could be to do with low memory so i've put some apps on my sd card, system storage 1.65gb used out of 1.97gb
I tired to back up via samsung kies (not sure if this has been replaced by samsung link) but wouldn't back up everything so I'm looking a solution without factory reset if possible?
The phone i have is a Samsung Galaxy S2.
Any help would be appreciated, this is really starting to melt my head!!!! :confused:
Thanks Stevie! Perfect solution for the problem on my Galaxy 3. You guys who post without reading the thread could save a lot of heartache!;)
omg stevie i LOVE u so much thanx iv been so pissed cuz it didnt work
thanks Steve :):)
- - - Updated - - -
thanks Steve :):)
- - - Updated - - -
thanks Steve :):)
Go to settings then application manager and go "all" tab and scroll all the way to bottom click on "download" and enable it :)
Thanks so much. Worked for me on my galaxy s4.
you're our savior! :-*
Hi Manpreet, hope you must have resolved your problem b know,...since I saw ......thought of sharing the resolution....I had the same problem with my samsung S3, with my contacts, "unfortunately.......".........the constant message pop up even if I try to use contacts and my dial pad as same connected to contacts.....
Now what I understand is that last night I was trying to close my applications to save on with my battery life....now I disabled my contacts along with other applications like s suggest etc....to restart the same go to settings....application manager......slide it to the right "all" go extreme down, there you see the applications which has been disabled....now enable the one which is giving you trouble...or else you can try one at a time ....you know the method of elimination....try to enable the most suitable first and hope that you get it resolved...I got my thing resolved and all my contacts were saved as well....hence thought of sharing....till then all the very best....regards....Amarjit Singh
hi there i have a sony xperia android mobile with modele number MK16i and i have the message'' Unfortunately, the process com.google.process.gapps has stopped" always appear and i can't access to play store or any application. can any one help me pls .
hi stevie i have sony ericson xperia MK16i and i didn't find the application manager ....i just don't have it!! and this damn message keep appearing for more then a month....can u pls help me out. i will be appreciated ty.:)
it didn't solve my problem. my s3 still shows that message. and it hangs too. please help
Thank you soooo much Stevie Euginio....Saviour!!! .. Mal Timmons
lilyo7788
