- Sep 16, 2012
- 5,534
- 0
- 0
Mobile-review.com ����� ��������� Samsung Galaxy S6 (SM-G920F)
Ill post the points most people want to know
BATTERY
Under their test, they got around 3.5 hours of screen times with Auto-brightness cranked to the max, and data transmission in 4G. Also got about 10.5 hours of on time
"Expect that this model will work as much as 4 Note, not worth it. But the result was slightly higher than the iPhone 6 with the same load (number of calls, the transferred data). The difference is almost invisible, it can be said that these devices live at the same time. Again, for most people it will be a full day"
TOUCHWIZ
"As Samsung began to simplify shell TouchWiz, and Android 5 is clearly visible. While this is not a pure Android, but a lot of clutter removed . . . the system began to look simple and understandable."
AUDIO QUALITY
According to the speaker volume Samsung S6 pleasantly surprised, despite the fact that the speaker and one is in the end - it is very clear and loud enough for almost under different conditions. The video shows the differences with the S5, they are visible to the naked eye. You can talk about that in sound is one of the most high-profile devices and pleasant company. Vibrating alert is average, there's no achievements.
CONNECTION
The quality of the phone connection is not unsatisfactory in any form. Tried to find differences from its Note 4, could not find them. The quality of work in LTE as flawlessly, drew attention to the fact that the phone is better clings Wi-Fi-network than Note 4. Subjectively it seemed that he was in the whole communication quality a little better.
CONCLUSION
By and large, Galaxy S6 was very pleasing, functional, and what you expect from the machine line Galaxy, but also there is no memory card that many consider a minus. Comparing this model with similar devices in the same price range, we can say that they are very inferior in all respects. This device without any compromise, the best in almost everything. Subjective things can interfere with personal rejection of design and / or to Samsung. But this matter is so thin that it makes no sense to discuss them. From a market perspective, Galaxy S6 sets the bar very high in both productivity and everyday usability. The ergonomics of this device just fine.
BATTERY
TOUCHWIZ
AUDIO QUALITY
CONNECTION
CONCLUSION
