Samsung Galaxy S7 Edge makes a stock musical riff whenever a Bluetooth connection is made.
  • Start date Start date
A
AC Question
Samsung Galaxy S7 Edge makes a stock musical riff whenever a Bluetooth connection is made. For example, I connect the Bluetooth at a Bluetooth speaker. The sound happens. I connect the Bluetooth to my Fitbit. The sound happens. No this wouldn't be so bad (though I wish I knew where to look to disable this), but the phone will periodically do it by itself. It appears completely random. But it MIGHT be that a Bluetooth device "disconencted" and then "reconnected". Thus the original problem. I can't do without Bluetooth devices. But the sounder is making myself and other people crazy.
Press volume button, the volume control should pop down, tap the down arrow icon in top right corner. Another menu should drop down. There you have the granulated volume controls - try turning off the systems one...
BOb_marley
