Samsung keypad
Here i saved you the trouble of having to find it ;)
Push it to /system/app
Thanks. If found the file on another android forum and pushed it last night, but kept getting FC. Hadn't reboot or cache wiped, so those will be first to try. I'll let you know.
ok, so i copied the apk fike into system / app and rebooted as well as cleared dalvick and cache and i get nothing but FC. It shows up as a selectable keyboard but isnt usable. the other droid forum (where i found the file) said something about one or two other files that needed to go with it. maybe i was reading about a wrong process but i dont know enough about it to be sure. I'll download your file (thank you) and see if that works.
Little off topic but still about Samsung Keyboard, how do you turn off the click you hear when typing without silencing phone dialer? Can't find a way to do it in settings?
Settings-Sound Settings-Uncheck "Audible selection"
As it turns out, I am looking for the stock Android keyboard. I think it is the 2.1 eclair keyboard. Not sure.
Taylor Bag
