Samsung Moment battery life
is there a charger for this phone
The Samsung Standard Battery (AB653850CA), manufactured by Samsung is compatible with the Samsung Code i220, Propel Pro i627, Moment M900 and Behold T939 phone models.
Ok, this is getting ridiculous. I took my phone off the charger this morning at 8am and by 1030 it was dead. Now I'll admit I was running the phone hard, with numerous apps going and music going...so that could be why. So it died, and I plugged it in using the wall charger and let it charge up again. It finished charging at 230 and I took it off and wrote two text messages and downloaded one ringtone from the Zedge app and it dropped from 100% to 90% to 80%. Its currently staying at 80%, which is odd. I just swapped my Hero for this Moment last night and so far am regretting my decision. Ugh...gonna wait and see if this charge holds longer. I like the phone (at least the physical keyboard), but this battery life and the overly bright flash just aren't cutting it...
I had difficulty with the battery in the beginning and the store manager at sprint told me to turn off the GPS, Wi-Fi, and make sure i'm not running applications in the background. I figured that i really didn't need the GPS or the Wi-Fi all the time and i also installed a program called task killer, this has helped with the battery life and now it doesn't drop as soon as i take it off the charger. you can also go to samsungs website and they have a guide there with tips on how to increase your battery life.
Just a note, I had a moment that had some various issues, including w/ the battery. My experience (and this isn't across the board as accepted) is that with conditioning, the battery life improved. I did exchange the phone and just got my 2nd moment, the battery life is much improved...We're talking dramatic improvement. At this point it has not been conditioned.
Observations
Hello. This is obviously a major issue. I've read for some time, and can't say that I will finish readinig all of it anytime soon. Just wanted to add my observations.
Whereas NiCd batteries have memory issues, LiIon do not. Conditioning should not be an issue. Truly stated, allowing LiIon batteries to fully discharge is not beneficial to a long life. The phone tells you to charge, it might be a good idea. No flames needed, just take a look at batteryuniversity.com. Good information, stated plainly.
True, the GPS, WiFi, and Bluetooth do use battery. The latter being the lesser of all evils. But none in fact are likely to be the root of the problem.
Your phone sending packets, or rather redundant packets back and forth over the data services is likely more of an issue.
Normally the phone will communicate with the network. But if the connection is sporadic, or there are errors in communication, the phone will resend packets (packages of binary data) to reestablish itself. So, being in and out of buildings, or on remote highways where coverage is inconsistent, will make the phone work harder to "talk" to the network. Transmitting uses juice.
Obvious, huh? Sorry, I'll get to the point.
Established connections such as WiFi don't have many errors if the signal is strong enough to connect to the phone. So the phone isn't overworked.
GPS is receiving only. Your phone doesn't tell the satellites where it wants to go. The software responds to a signal.
These shouldn't be real issues. The screen being on consistently will use more juice than the processor is eating from all the apps that we feel we have to consistently close.
But we want to look at it, huh?
The issue is in the connection. This is relevant to data, btw. If you are in a city and access 3G solidly, surf your brains out. But do it when you choose. In the middle of nowhere, or in spotty areas, you'd probably give up on surfing eventually.
But your phone might not.
If you have background data sync on, your phone is going to go look for email every few minutes. Power lost. Sync your contacts. Power lost. And heaven forbid, if you use a 3rd party visual voicemail that isn't spot on with it's forwarding of notifications to you, lotsa power lost.
I can't vouch for VM services I have not used, but research them for yourselves. Your phone will be like a dog with separation anxiety constantly running up to the network thinking "do I have voicemail? do I have voicemail?". It's nice to have visual voicemail. Excellent features. But what use if all the voicemail is coming in because my phone died? The VVM service uses the net in many cases to update your phone. If it has no steady link, it's going to irritate the dog.
Background data sync. Do we need it? Sure, if you are waiting on an important e-mail and cant be bothered with pushing your inbox icon. If you're adding several contacts a day to your phone and can't take a moment to sync them yourself. Just plan on having your phone plugged in a lot. See data synchronization in your main settings. Easy fix.
It's more of the nervous dog. Eventually the dog gets tired out, and sleeps.
I'm sure there's more to it than this, but these were my thoughts on the issue. I won't quote data, but I had an issue, got rid of background syncing and visual voicemail, and all is good in the world. I access the web a lot. Have it on WiFi at home. No real issues.
So to end my rant, I ask that you teach your phone to be mellow, and see if a few easy habits won't solve your headaches.
I hope it helps.
Thanks to the posters here that piece by piece led to the solution I suggest, and thanks to you for your time spent reading.
Happy New Year.
K
the OEm battery does die soo fast... with alot web surfing and texting the ones on ebay really does add an extra 2 hours cause fully charge lasts me alot 8 hr.... i have 2 other extra fully charge battery one in my work locker and one on the car
I've have this battery problem with my Moment as well. You just have to know that the battery will most likely last you the whole day with moderate use and periodically killing apps running in the background. Fully draining the battery a few times definitely helped with the battery notification (whether its a software issue or what I don't know).
The other thing I noticed is even when it says I only have 60 or 30% left, it lasts a LONG time at those percentages. Right now it's at 60% where it will stay for quite a while before going down to 30 where it stays for the rest of the evening.
I use Advanced Task Killer which works the best I've tried at easily killing apps.
I wish we could stop the phone from dimming when it hits 15%. This bugs me so much.
Sprint released an update today (Jan. 15) for the Moment that is supposed to help with battery life. You have to take the phone to a Sprint store to get it though.
Just took mine in but the tech wouldn't upgrade it. They said it has failed on two of the store phones they tried and their internal blog site is reporting failures all over the country. May just be a training issue at the local store.
My battery life seems to be better these days. My battery doesn't go yellow until about 4pm (being on since 8am) where it usually went yellow at around 12pm.
Thanks to everyone posting here. The battery life is the only thing keeping me from going out and purchasing the Moment right away (currently using my BB). That being said, I sure hope they're able to do the update at my local store (Cleveland, TN), because I plan to purchase the phone outright (amazon.com or ebay, if I can find it reasonably priced). I'm going to have to buy it new, as I just got my BB three months ago.
So can anyone actually tell me if the update truly helps the battery? Thanks everyone, I love this forum!
depends on your uses and expectations. My phone is in the red at 9pm so I got 15 hours and it was in my office buillding all day in Roaming mode. I played music during lunch for 40 min.
Im happy
I have notice that about the battery bar that is not reliable at all,which is not good.I got the red bar and a message saying that I was on 15% battery left to charge it,since that it has been like 3 hours and I have been surfing the net and doing all kinds of thing with the phone and hasn't die on me yet.Go figure!
Hm...so the battery isn't really what's bad, it's the "percentage reader", right? That's what I've been hearing. If I can get the phone, then get the CL14 update, I'm really hoping it fixes that.
@g.711-wow, I haven't heard of anyone getting that kind of life, and while playing music nonetheless! All I'll be doing is texting usually, maybe visit a mobile site here and there. I usually don't use my phone for music (Zune HD lol). So could you give me a life expectancy from that type of usage? Thanks much!
Depending on your signal strength (weak strength eats battery), you should get about a day. I've only had my Moment about a week, but I've been consistently getting about 24 hours with some browsing and game playing. I did turn off my gps, and wifi though. You can also dim your screen.
Like everyone said, when you get to 15%, you've still got several hours left.
There is an update that includes a fix for the battery. Just remember, the update is an "instore" update, can't be done OTA but none the less. it tookl about 15 minutes for mine and it did improve my battery life from about 4-6 hours to about 8-10 hours depending on my usage.
I have taken my Moment in for the update and was amazed at the change in battery life. I use my phone pretty heavy for surfing, txting and such and used to have to plug it in within 4 to 5 hours. Now I can go almost two days before having to worry about it.
It is true that my phone would show an 80% charge after a very short time and now will stay at 100% for a few hours. I am not sure if the fix is for battery reporting or actually cleans up messy coding. I am convinced that some of the Samsung proprietary apps do chew up the battery. I had a moto droid for two weeks before having to switch to sprint. The Droid does not have any of these "apps" and lasted longer on the battery.
I really hope that when 2.1 is release, that it will negate the need for these apps and remove them.:confused:
battery fix
I just got my moment this week. I read a lot of reviews before buying and the main thing I read was the battery life. However I read a couple post about people advising to drain the battery completely to where ure phone complety turns off and tht this will reset the battery. I am here to tell you it worked perfectly. I have my phn on all the time, I did make sure I had task killer which helps. I run tje pandora radio app all day at work. I do a lot of the time plug it in but I did test it. I played the radip with the different cd cover graphics that shows on scree for almost 3 hrs and still only used half the battery. I have not a problem with it dying on me. The way I see it, its good enough and I'm close enough to plugins to plugin we I need to. Having phns tht. Run like computer r going to have battery issues, but I believe draining it will help.
mama baer
