- Apr 9, 2012
- 181
- 2
- 0
fetterjohn and KillBillCDP2 -
I can see the option "Move to SD card", but I believe it does not move the app to the external SD card. It only moves it to the SD Card mount point (/sdcard), which is actually within the phone's storage. That's why my question was, how to actually move the app to the external SD card, which on my phone is /sdcard/external_sd/
At least on my E4GT, when I do the above procedure
Settings->Applications->Manage Application->pick app->Move to SD card
the app now shows up under the "On SD card" tab with a green check mark making it look like it's on the external SD card, but in reality it gets grayed out in my apps and is no longer available to use. If I look in the external SD card (/sdcard/external_sd/) using My Files, the app is not there!
That was my same concern, since when I looked at the apps under "sdcard" it showed I had like 11 GB of free space.. my "external sd Card" is only 2GB, thus I do NOT believe apps get transferred to the external sd card... although I did notice that my photos that I had on my sd card were not visible when I removed the sd card and re-booted the phone, so at least some information/files can be moved to the sd card...
