brnscofrnld
Active member
- Sep 15, 2011
- 32
- 0
- 0
I only had that issue with my OG DROID on one certain charger. Other chargers did not do this with my screen.
Try a different cable.
No. I'm saying its normal.
Sere s an example if the sts digg the washtub
screwed as in always having this issue?
no case, extedned battery, and holding it
I'm thinking my problem might have something to do with my USB extension for charging. Is it bad for me to just leave it the way it is and just take it off the charger when I'm using it (or living with not typing while it's charging)?
i didnt use my extender last night and i noticed it slightly compared to terribly like before. like the swype follow trail was still kinda jumpy but it did type fine, also scrolling on webages jumped a little bit still. but looks like no extender for me :'(
You didn't say you were using an extender. There's the cause of your problems.
Motorola says to use the original charger and cable for a reason folks.
