Screen protector
I have no interest in the WSD glass protector. Way to lazy for that whole installation process. I'm using these and the installation was easy. Works well with my case and the S Pen and doesn't feel sticky. Hopefully it holds up well.
I also purchased these and just installed one tonight. Silky smooth. Feels great. Liking this a lot so far. Plus lifetime warranty even if it gets damaged over time!? Nice!
My ESR tempered glass screen protector arrived today. It was super easy to put it on with the included frame. It looks really nice and feels really smooth. S-pen works awesome. At first, it was hard to reregister my fingerprints and I thought I'd be using face recognition, but once they got going it went quick and the fps works great so far. I registered thumbs and index fingers like I always do.
Only thing I don't care for is there's a visible circle where the fps is. You can't feel it but you can see it especially on a white background.
So I've got the ESR Echo tempered glass case, and the ESR screen protector as well as the ESR camera glass which was also super easy to put on and it looks great too. Wish that was clear though instead of black. I couldn't find any that were not black.
I’m glad they worked for you. They didn’t for me. The fingerprint reader worked for like a day and then wouldn’t read.
I ended up with the IK ones and they are great.
Ringke are not black. They are clear glass.
Ok. I just installed the dual wing. I also had another amazon purchased "soft" protector on it.
I hate them both. Why? I don't think these soft protectors are made for using an s pen. Every word that I write on the screen literally leaves a mark/groove in the protector. I can see every word I have written. :/. Basically. You'll need tempered glass or nothing at all. :/
I had the same issue until I put the grey tip in my s pen. Problem solved. If you have any s pen tips left over from a previous note. They grey ones are for softer surfaces.
Yes... I use the Spigen TPS cover and it required the grey tip on my Note 8 sPen and all smooooooth.
Hmm... now that's interesting... just installed the Spigen TPS cover on my N20U last night... and no spare tips. :-\
Samsung!! Fricken nickel and dime-ing us couldn't even toss in tips. Gotta find out who to call to get/order tips.
WOW I had zero luck with my 2 ESR . But in the past no problem with thm. They didn't reply to email emails looking at some of the reviews now they are not glowing by far
The tpu film I bought started bubbling up once I put on the case. It's only in a few spots so I'm trying to deal with it because my fps works great with it. I don't want to waste more money.
LK [3 Pack] Screen Protector for Samsung Galaxy Note 20 Ultra, [Positioning Tool] [In-Display Fingerprint Support] Maximum Coverage HD Clear Flexible TPU Film https://www.amazon.com/dp/B08C1YMBJ...ag=hawk-future-20&ascsubtag=UUacUvbUpU6845519
Going to have to keep this one in mind if the Spigen one doesn't work. Applied it last night and wet install so let it cure overnight and bubbles gone but at work with Note at home so will finally power on and try.
Does the LK have much orange peel?? Like the idea it's a dry install and give you an alignment kit but been happy with Spigen on my 8.
No orange peel at all that I noticed.
kutty7
