Screen rotation sensitivity setting?
RobFreundlich
71
OK, it's time for an "I'm stupid" question: I found a setting somewhere, and lost it.
Specifically, I am pretty certain that some time in the last month or two, I saw a setting to control the sensitivity of my GN2's screen rotation sensor. I don't know whether it was in the OS or some third-party app, but now I can't find it. Does anyone know where I might have run across this?
I have not seen Any control for this but I could be wrong.
From my Galaxy Note 2 via Tapatalk
Only one I am aware of is smart rotation under display. It uses the camera to look at you and figure out the screen rotation.
Could it be the gyro calibration? That's in:
System settings > motion > advanced > gyroscope calibration
Sent from my Samsung Galaxy Note II
That's not it, although it's a useful setting (and one I didn't know about). This one controlled how far you had to go from horizontal to vertical (or vice versa) before the screen orientation would switch.
That's almost definitely a third party app
Sent from my GT-N7100
Haven't seen anything in this. Bit sure if it exists. I know it's an option somewhere (probably hard coded by the manufacturer) because some devices are definitely more sensitive than others.
Is there an icon for "smack self on forehead"? I just found it, and it has nothing to do with screen rotation. If you enable "Tilt to zoom", and then go into "Advanced options", it's there under "Sensitivity settings --> Tilt to zoom".
I don't actually use TTZ, but I must have played with it at some point and seen this, and then transposed it into screen rotation. Rats!
Ah, thanks for letting us know.
I found it on my phone. Go to settings. Select general. Then go to gestures. Scroll to the bottom and you will see motion sensor calibration.
Taylor Bag
