Seidio 3500mAh Battery for the Incredible
CRKhead
559
14
I received my 3500mAh battery from Seidio today and wanted to give everyone some preliminary thoughts and pics...
The first thing I noticed is the feel of the new back cover. Seidio's soft touch coating does indeed give it a soft feel, but it does not feel flimsy. It feels "sure" in the hand, not slippery, and even though it is a bit bigger than the stock battery cover, it maintains the "Race Car Finish" that HTC was going for. While the extra bulk may not appeal to some people, it is definitely something I actually like. The extra "humps" in the back give you something to hold on to when holding the phone in your hand and the ridges that are part of HTC's design also add to the stability. Some people stated they wanted the cover to be increased without the steps, but now having it in my hands, I disagree. If the back cover was increased in size in one piece, like a brick, I don't think it would be as comfortable as it is now, and it definitely would lose those extra design touches that make the Incredible stand out...
Next is the battery itself... It is MUCH bigger than the stock battery. It is rated at almost 3 times the capacity of the original, and as you can see in the comparison photos, almost 3 times as thick. Even with all the extra bulk, though, it only adds an additional 7/8 of an ounce to the overall weight, so those worried about it making the phone too heavy to hold can relax.
I can't wait to really put it through it's paces and will be charging the battery overnight. It states that it should be charged for at least 8 hours and subsequent charges should be left plugged in for an additional 2 - 3 hours after the charge indicator turns green. It also states that the battery will increase in performance after 5 - 6 charge cycles. Due to the charging issues on the Incredible itself, this may require "Bump Charging" a few times to get it to full capacity if it is charged in the phone. I'll let everyone know how it turns out in a few days!
Wow. That's a monster.
I agree that the race car back looks nice. Can you post a pic with the battery in the phone?
Looking forward to seeing how the life is.
I'm going to be running my 2150 down to 40% tonight and then I'll charge the 3500 overnight and start fresh. I'll take pics of the phone with the battery on, but it's going to be like all the other pics of the extended backs... The pics don't truly represent how it looks, or feels...
A couple of other things right off the bat... The 2150 extended backing will NOT fit on the 3500... It is like a fraction of a millimeter too shallow in the middle. Also, if you modded a current case to fit perfectly over the 2150's extended back, it will NOT fit on the 3500's back cover. If you mod a case to fit the 3500, it WILL fit on the 2150, but there will be a few spaces...
Did you order that from seidio? Thanks for the great info. You have big hands to do you like the 3500 feel better than the 2100?
www.remtekservices.com
I just was showing initial pics as I want to power off the phone tonight and put in the 3500 battery to charge overnight... Tomorrow I will post pics of the battery on the phone...
I'm going out fishing tomorrow just offshore, so I'll have a weak signal for a few hours... That should put a strain on the battery and give me some good preliminary numbers.
The hole for the camera lens looks too small -- is this the case? It is much smaller than the OEM case.
If you're talking about the camera hole being much smaller, then yes... I'm going to test out the camera tomorrow on the boat... I'll take some pics with the back cover off completely, then take the same shots with the cover on and see if it makes a difference... Here are some pics of the phone with the 3500 cover on it... You can see how the ridges give you someplace to hold the phone more securely...
Man I just don't know. Sometimes it looks ok and sometimes it looks bad. These are better pics then other thread I saw.
As I said, the pictures don't do it justice and the extended backs really do make the phone feel better in your hand...
Can't wait for some more pictures and some review on how long it lasts! Great looking back looks a lot better than what I was expecting it to look like.
Wow it don't look bad and it does look like it's going to be as great to hold as the 2150. Have fun fishing and good luck.
OK, so far I am at about 9 hours unplugged and used the phone HEAVILY using 3G only, no Wi-Fi... I broadcast about 20 minutes worth of video on Qik, streamed Sirius/XM for 2 hours, took several videos and a lot of pictures, surfed the net, Facebook, Twitter, used Navigation for 30 minutes, email, text messages, and a friend played a game for 1 hour straight on the ride home while XM was streaming... I sit at 62%! I really hammered this thing...
Oh, and as for the back cover blocking the camera lense? No worries...
The Boat...
The Bait...
And one of the Mates on the boat... I couldn't believe it...
Pictures came out with no obstructions...
Battery Stats are as follows...
Cell Standby 21%
Camera 21%
Android System 21%
Phone Idle 16%
Display 8%
Maps 7%
Qik 4%
Mediaserver 2%
Wow.....simply wow. The battery life on that thing is insane. Hows it feel in the hand while using the phone for a call?
Impressive results thus far... I'm only worried about how bulky it is; not necessarily for hands but for my pockets lol
Thats the one I got and after rooting swapping to the Undervolted Hydra Kernel (less power usage by 100 / 25mv respectively) and recalibrating the battery by deleting the batterystats.bin I can get 17-18 hours of it under pretty heavy usage. Normally, since everyday varies, I manage between 14-16 hours on it.
lusiyana77
