Multitasking on sense is garbage. Not sure if I should try and defend my opinion on that lol.
Sent from my EVO using Tapatalk 2
I do think that HTC will fix this with an OTA here in the next week or so. Most new gadgets tend to have updates pretty quick after release.
They should also include an update for the camera shutter button. To make it auto focus when holding it down half way.
The worst thing for me so far is the dropbox. Since using the phone as usb storage wasn't working I decided to transfer some music through dropbox. I clicked export on a bunch of files and like normal switched over to do something else. Problem is, when I went back all the exporting had stopped. Basically if you are going to export files from dropbox, you have to sit on the dropbox screen and wait for it to completely finish.
I am going to test this method and see if helps fix the issue until we et something more official or a Rom that fixes it.
I think I have found a fix for the multitasking! (Video inside) - xda-developers
You guys do know that HTC has said there's nothing to "fix" As far as multitasking is concerned, right? Now, they'll hopefully change their mind, but it doesn't look good right now.
Those of you who have been able to play with it for a day or so...what are your thoughts on how the phone handles multitasking?
It's frustrating to read stories like yours and then hear other people say "works perfectly, best phone ever, only someone looking for a problem would notice this". Do most people sit and watch their app download so they don't think there's a problem?OK, I have the phone now. Multitasking is most certainly "broken". One of the first things I did was go into marketplace and download an app. After it started a VERY slow download, I decided to test the camera while it was working on that. Went to the camera app, took a few pictures. Went back to Google Play and it was as if I had never been there before. It apparently totally aborted my download, even.
I am *NOT* impressed. I can't even use just TWO APPS at the same time now?
