Share your Galaxy S5 screenshots!
Homescreen, all on one screen, with private things blacked out....
very much inspired by a screen/theme I saw on mycolorscreen named "popsicle freshness"
Mine, made with all apps from the Google Play store:
launcher - Nova Prime 7x4 grid
icons - Ninja Camouflage Icon Pack, Tiny White Icon Pack
wallpaper - Premium Wallpaers HD
dockbackground - DCizonZ
Weather widget - HD Widgets
calendar widget - Simple Calendar Widget Pro
search bar - Custom ICS Search Widget
How did you get this theme? Did you use Zooper widget pro and some kind of icon pack?
zooper widget pro, and IIRC stock icons. i made (and attached) a wallpaper of the widget, so it's easier to work with.
How exactly did you make your home screen like this and what launchers did you use? I love this look!!
Posted via Samsung Galaxy S5
thanks! i used zooper widget pro, and nova launcher. see my previous post (just above this one)...a wallpaper to get you started.
Stock KitKat look
I have another question. Is there any fix to the white backgrounds? I prefer the dark ones that the Android 4.4 had.
Material
Posted via the Android Central App on my Galaxy S5
Verizon Galaxy 5 with lollipop using Nova Launcher
fidsomedia
