Share your Galaxy S5 screenshots!
It would be fun if you could double-tap the lightbulb to make the screen go off. Might be able to do that with DTSO. It lets you stick a transparent widget anywhere on the screen to turn the display off on double tap.
I actually have double tap to sleep with action launcher activated, so that's working. Pretty neat right :p
My Galaxy S5 on 5.0 Lollipop
Posted via the Samsung Galaxy S5
Material Google Now
Posted via the Android Central App on my Galaxy S5
Stock Lollipop look for me! Nova Launcher Prime + Lollipop Icons + Moonshine Icons
Posted via Samsung Galaxy S5
More material
I need to just wrote a cron job that likes anything that vlad posts, because I'm just going to do it anyway. It would save a lot of time.
I have a small problem here. I tried to use a few launchers like nova, dodol launcher and others. for example this is how my menu looks when I use Google Now Launcher:
in other launchers I tried it's either the same or normal except it has widgets in the menu too or it scrolls downwards instead of right or left.
What I want to change is just the icons, I want to have everything else exactly the same as it is in the touchwiz without modifications. Can I do this? If yes, how?
My latest. 1W weather widget + power toggles.
Still trying to decide how I want my homescreen. On my old phone I tried to showcase photos I took but this route gets a lot less fuss from me. That empty space is serving me well as a spot to stick ColorNote widgets.
Pretty happy with this setup. Will probably change it very little until my upgrade.
Minimalist.
Just updated. Clean and minimal =D
Posted via something Android
mmn112233445566111
