Share your Note 9 home screen!
What app are you using to change the navigation button design?
Oh sorry I meant to answer earlier. I have a "leather" theme on here as well which includes gold navigation buttons. Also see the keyboard and messaging app screen
Current setup. Nova launcher - whicon icons - Zooper widget
I LOVE your Zoopers widget! Does the battery status have to stay in the setup or can you turn that feature off?
Thanks nope you can remove it or add anything else. Also you can add shortcuts by clicking anything, for example date goes to calendar and time goes to alarm.
Also here is the notification / status bar using app powershade, who needs Android pie ? Completely customizable.
Good Lock (Galaxy Apps) w QuickStar should give you the same options/customization.
Simple!!! Rootless Pixel launcher with the awesome Google feed on the left of home screen
Can't use any launcher which doesn't have the Google feed support so Samsung launcher out of question even though I like everything else on it.
Nova Launcher, KWGT Kustom Widgets, Sesame Universal Search and Shortcuts for custom long-press shortcuts
I usually run with a very clean home screen and keep only a few icons in the dock. With the Note 9 I've decided to let the dock go and just use Edge Panels for my most used apps.
Nova Launcher, some Zooper widget that I customized, Today Weather widget and an AMOLED live wallpaper that isn't done justice with a static image.
dumpsterrentals104
