Show us your S22 cases!
Yea, but it is a good feeling case. Has a soft velvety feel to it.
Have a cheap Poetic Neon orange thing coming in tomorrow :-\
Oh cool looking forward to the review ...I've been using the Ringke matte clear exclusively not going to buy another case for once hold off on getting too many cases ...
I have been looking for a case that will hold a few cards but still allow wireless charging. First, I got and am using the ATRAING case from Amazon. https://www.amazon.com/dp/B09PNJDGG...ag=hawk-future-20&ascsubtag=UUacUvbUpU7054535 It allows wireless charging for me on two different wireless chargers even with 3 or 4 cards slipped in to its backside. The case holds those cards with a slight bulge on the back. If you limit yourself to two cards, there is no bulge. That case has two problems for me though. First, the bezels only come up just short of the phone’s thickness. So, the curved edge of the screen is exposed and not protected. And, if you put the phone face down the screen, and not the case rests on the table. The case needs to be about 1/8 of an inch thicker. The 2nd problem is that the buttons on the side of the case have no tactile feeling at all so you can’t really tell when your finger is on one of them without looking. Eventually after getting used to the placement of the buttons, that may be less of an issue. It is unfortunate this one does not have high enough sides or bezels as it does allow charging.
So, I then ordered the Smartish case from Amazon. https://www.amazon.com/dp/B09MG6T98...ag=hawk-future-20&ascsubtag=UUacUvbUpU7054535 That one has a raised bezel top and bottom which allows the phone to be face down without the screen contacting. However, the sides are lower, with no bezel and expose the curved edge of the screen. The buttons are very nice to the touch and it will hold up to 3 or 4 cards easily. The problem is that even though the case is advertised to work with wireless charging, it will not work with either of my two chargers. On one of the chargers, if I remove all the cards, it can be made to work. On the other charger, the entire case must be removed to work.
A post above recommended the Galaxy Damda Glide Pro Case. Unfortunately the seller and manufacturer say that case does not allow wireless charging.
So, unfortunately the hunt continues for the unicorn case that will hold 2 or 3 cards, has bezels tall enough to protect, and will allow wireless charging.
Update: Returned the Smartish wallet case as it did not work with wireless charging as claimed. Just ordered another case that has reviews saying wireless charging works:https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU7054839 As noted in a previous post it is unfortunate the ATRAING case has no raised edge bevels to protect the screen or tactile side buttons, since wireless charging does work with that case.
Do you keep all these cases why do you need so many cases? You're about $300 deep in cases, don't you consider that a waste of money?
Yea, I keep 95% of them and Yes it's a waste of money. You should see all the $$ I wasted on iPhone 13 Pro Max cases :-\
I need an intervention bad :p
Your case fetish doesn't make any sense.. it's only meant to protect the phone. I had multiple cases on different phones but they were usually cheap eBay/Amazon cases. But you're buying case from the bigger manufacturers that only sell at retailers. Yeah dude chill out you probably end up trading your phone in next year anyway
I'm gonna say get as many cases as you like.
Anyone have a suggestion for a good case with a card holder, supports wireless charging and offers good drop protection?
That is the unicorn I referred to yesterday. I have yet another in this quest arriving Thursday. Hope the 3rd time/try is the charm.
I'm slacking, only have one other case on the way :-\
Who's going to keep this thread alive if I stop buying cases?
We need you! :D
I thoroughly enjoyed seeing all the watchfaces you posted for your Galaxy Watch 4. I have a Galaxy Watch 3 & I couldn't even purchase any, but I liked seeing your watchfaces with the matching watch bands.
You've posted phone cases I've never even heard of. It's quite informative.
You do You! I appreciate it!
:D :D
I buy too many as well. Have seven or eight for my xs max and maybe six for the note 20u. Only bought two so far for the s22u but once some nicer ones come out I'll get a few more. Tech21 and Mosnovo made some super cute ones for the iphone. If I get a 13 Pro Max I'll get the whole Care Bears/Hello Kitty collection from Sonix.
This is the Lifeproof Next case. It is so solid with great drop protection and covered ports and it feels great. Adds a bit of width but not thickness and it feels good to hold even with my small hands.
CliffHangerOld
