Show your Homescreens! (not mobile or dial up friendly)
Con't. Screens 4-7
Just curious, what is the name of the app of the GMail icon with the mail count?
Thanks!
awesome, thanks!!
btw, how did you remove the grey bar from the lock screen?
they have the whole theme and just the lock screen ill go back and find the links for you if interested
thanks, based on some posts on that site, I'm not supposed to unzip the files, that's were I was seeing the corrupt msg. So i just need to put them on my sd card, power off, hold home when I boot, right?
Thanks man!
Thanks man!
make a backup first(VERY IMPORTANT)
move the zip file to your sd card (no folder just in the base of the sd card)
from the recovery screen select update zip
choose the clear zip file you just added to your sd card
after thats done reboot the phone again
I had several zip's in the root of my sd card, so I chose 'choose zip instead of update.zip'
Do you know what the differences are? I noticed handcent corrupted and had to reinstall it, a couple of apps renamed, but verything else looks ok, and yes clear lock is there :)
yeah after i flashed the rom i had to uninstall and reinstall all my apps
NOW BACK TO THE TOPIC post up your HOMESCREEN
I'll post some when I get some new scenes made. I just download a crap load of images and will start making wallpapers tonight.
Thanks for all the help 702DROID!
btw is there a way to remove any of the themes like clearlock without restoring my backup?
Im still REALLY REALLY NEW to all this so my answer to that is no lol maybe there is. I just did a backup restore on mine right now to remove the clear theme and reflashed the clear lock on.
You'll have to restore a backup or reload a rom without the changes. You can;t just undo it. but restoring or reflashing is pretty easy, so give it a whirl.
rebuilt
