Skype available!!!
Thanks Retired,
May I ask why did you uninstall it. Did it not work?
Yea it worked great at first but when I tried it again we were upside down and had to turn our phones upside down to see each other right. I was going to uninstall and reinstall. I just haven't gotten to the reinstall part yet. I went to the apps drawer then MENU>REMOVE APP> and then just selected the Skype app and hit uninstall.
Reactions: lovy
lovy, either will be in the data/app or system/app part of the phone, will not be able to get these system structure without root. Should be like any other .apk file go into menu-settings-apps-download-select app wish to remove-click remove. Done!!! By the way did you get it up and running lovy?
Reactions: lovy
Hi Acm,
thank you im not rooted still learning how to use the phone came from iphone4 and no i didn't install it afraid i will do something wrong or it won't work at all, my luck sucks
lovy, I will never suggest to do something someone feels uncomfortable about. I will say this thou, I am on my third phone which is not rooted either, at which still may not I have some other issues with Verizon @ the moment. This how I did it thou, first make sure unknown resources is checked in the apps section under settings, went to Droid-Life as BigJohn stated find the first mirror link(mirror) clink download after the download popped up, download the file in which will be saved to download folder on the sdcard/download and from there use a file manager like; astro, es file manager, etc. then used my file manager to open the .apk to avoid any parse error or other complications to open and install the app.
Now I restate to anyone this is my choice and how I did the install, means to any other way is by one's on choice!
Reactions: lovy
after 3 failed installs (mostly parsing errors)
i realized i had to edit the download name
to: "skype.apk" and then it would allow itself to be installed when clicked through the ES File Explorer.
hope this helps someone else out!
Reactions: Turbo Paul
if i just wanted to talk TB to pc without video which is the best Skype to download? as I stated before I saw in the market place the Verizon Skype is basically bloatware that cannot be uninstalled, this is why I am confused as to which one to install, I can wait for video just wanted to talk from TB to PC, and is this free? sorry for all the Noob questions.
lovy the one in the market is for other/older smartphones like the droid/2, incredible, dx, so forth uses minutes from phone plan if I understood correctly from last year. This new one should just use data plan if I am correct, if not someone else please advice.
One more thing to lovy, if you follow the instructions I provided with skype, you should be up on running to use with a computer. Provided you already a skype username ready to go or create one after the install.
P.S. lovy this app gives you a choice strait call with/out video!!!
Reactions: lovy
Thank you acm for always coming to my rescue, I hope my noob status will eventually die down :)
If the Skype that I downloaded doesn't have video, will it show a video icon in my contacts' pages? Some of my contacts do have that video option in addition to the message and call options.
I'm asking because I thought I downloaded the mirror file last night, but - based on the "how to's" explained here - I don't believe that I did it correctly.
Thank you.
Just tried it out and working amazingly well for me. I was on WiFi; didn't try 4G at this time.
Positives:
1) The quality is very good. Not as good as my 2 mp Logitech webcam according to my girlfriend, but pretty darn close!
2) I like that I'm not stuck at my desk. Can move around. Can change to the main 8 MP camera to show people what I'm seeing.
Any negatives?
1) None really right now. I'm not having any "upside down" issues. No LED issues (though I think I disabled the LEDs in the beginning).
2) In the beginning, it asks if you want to sync skype contacts with your address book contacts- tried it without luck- likely because my skype contact names and my address book contact names are different. I'm sure this will be addressed, but not a big deal right now!
Thanks
Does this Skype app only work from cell phone to cell phone? I just now tried but failed to connect using my Thunderbolt to a friend's laptop connection. Actually, I could only hear voices, but no video. Frustrating. Also, why does the Skype app say that in the United States the app can only run using WiFi??? WTF?? If this is true, then this Skype app won't be much use to me if it can only run off of WiFi.
Skype Mobile (which is different from Skype app and exclusively for Verizon) works over 3G/4G too. Video feature only works on Thunderbolt. So you can have cellphone to cellphone video call only if your other contact is also on HTC Thunderbolt.
Reactions: Casey Cheung
Two days after downloading and installing this app, I finally tested it this morning. Placed a call to a contact in Kathmandu, Nepal - on her PC. I was on 3G. Voice was good. Being on 3G, picture was grainy and jerky but as I said, I was on 3G. I don't have 4G in my area yet and rumors have it that we will get LTE in our area in summer.
jtb
