Got my new Nexus 7 on launch day and despite some early problems with the OS (that seem to have fixed with a factory reset) and some more recent flubs (I've had 2 random restarts in the past 5 days since I got the new JSS5Q update), I've been happy with it.
But today I noticed there was some slight screen lift around the bottom edge [where the USB charging port is] of my tablet. I keep my Nexus 7 in a padded sleeve when I travel, and the only time I've dropped it was when I accidentally knocked it off my bed from about 2 feet up onto my carpeted floor, so I dont think it was caused by trauma. Honestly, if it had been there from the start, then I obviously did not notice it.
The screen lift honestly isn't bad, and it doesnt seem to be causing any functional problems. You really only notice it when youre holding that lower edge and can feel some give/space when you're pressing the front and back panels together, and you can also hear some faint "popping" when you do that. I'm mainly wondering if this is common and I'm just being nitpicky (like it's a build quality variant I can adjust somehow), or if I should be afraid of it getting worse?
