SMS on lock screen.
Here's a screenshot of the popup on the lockscreen:
ChompSMS does this :) which is what I use.
I've heard handcent sms can to.
I could not find the setting for it. I have to unlock the phone before I could read my message
Sent from my iPhone using Tapatalk
Just downloaded the app. Pretty nice. The only issue I've come across is that after you quick reply, the default messaging app still shows an unread message notification on the app the logo (on the app itself, not a notification in the notification bar) until you create a new message. If I could turn that off, I'd be pretty happy.
I am having the same problem have u figured out how to fix it yet. I haven't had a chance to google it yet
Which app is currently being discussed? I searched for Popup Notifications on the market, and nothing matched that description exactly. Could someone link to it possibly?
The Popup Notifications app name has been changed to Glowfly.
Thanks! I found it and it works great, I also have the problem where the stock messenger still shows unread messages even though I read them and replied through the pop up. Has anyone come up with a solution to that yet?
ludwig_mertz46129
