The gist of the problem is basically this: System-wide intermittent stutter which only goes away until you activate a screen recorder app, whether it be Game Tools, Nice Shot, AZ Screen Recorder, etc. Yes, you read that correctly - recording the screen improves overall phone performance!
Below is a list of posts that highlight this problem that I and a few others (and possibly many more who aren't aware) are experiencing. The common denominator here is the use of a screen recorder, which notably improves the overall performance / feel of the phone. This is the only known solution as far as I'm aware, which is completely unideal.
https://forum.xda-developers.com/s10-plus/help/lag-stutter-overall-choppy-t3914381
https://www.reddit.com/r/galaxys10/comments/btwfbl/anyone_experiencing_stuttering_or_frame_drops_on/
https://www.reddit.com/r/galaxys10/comments/b79cw3/is_snapdragon_really_that_much_worse_than_exynos/
https://www.reddit.com/r/galaxys10/comments/b4nftn/snapdragon_s10_laggy_on_4k_youtube_playback/
The following two are from myself. I initially thought the issue was isolated to video playback but it actually appears to be system-wide.
https://www.reddit.com/r/galaxys10/comments/ch172q/snapdragon_owners_does_this_type_of_video_play/
https://forum.xda-developers.com/s10-plus/help/sm-g9750-video-playback-throttled-t3950757
The lag returns as soon as you deactivate screen recording, which suggests that this is either a bug with the CPU or GPU not being optimized or boosting its frequencies properly, or that they are intentionally being throttled for whatever reason, leading to these stutters.
Bear in mind that these are all Snapdragon owners, I don't recall ever having this issue as a last generation S9 Exynos owner. If you are an S10/+/e Exynos owner, I would still suggest using your phone normally, but with a screen recorder active and then without, to see if there is any performance gain (as crazy as it sounds, it might actually make a difference).
Please don't brush this off as a non-issue even if your phone appears to be fine or snappy enough to you - the point is that your experience could be so much smoother / better than it currently is.
And yes, it may seem like I'm spamming this everywhere but this phone cost close to a grand and has flagship-level specs - there is absolutely no reason to accept its performance being limited in any way. As great as the phone is in every other aspect, on principle I will be moving on if this issue remains as it is.
