Soft Key Vibration issues!!!! Please HELP
nisime
My HTC One X (International Version) has issues with its 3 soft keys. they are no longer vibrating.
Battery was running low, so some power saver option was activated and it was then that all vibrations were shut off. Then I charged my phone and even though phone vibrations are working, the buttons are no longer vibrating. and YES, the "vibration" option in Sound Settings menu is checked, have unchecked and rechecked it several times... Have even restarted my phone several times, nothing works :'( :'( :'(
Could you help please... I REALLY need this to work... I think there is some application I need to go to, which initially shut the function off :eek:, but I can't find it in applications. Could you help? :'(
Sorry, but the issue got resolved... Somehow... :confused: :-[ After restarting the phone one more time the vibrating soft keys were back :) ... no idea how ;)
GabrielGallegosPalacios
