Solar portable charger or portable Battery charger for SGS3?
Which one should I go for?
How much power do you need?
The 5200/5600mahr units should give about two full charges. The 8400 should give you over three full charges. That is why I get the 10,000mahr Anker. I get about 5 charges from it.
If you just need one or two charges, go with the cheaper one.
The Anker 5600 mAh one seems to be a little rip off comparing to the Yubi Power 5200 mAh, so I will choose between the Yubi Power 5200 mAh or the Anker 8400 mAh. I think the 10000 mAh version of the Anker is too big for me. I can't really accept the size of anything bigger than my SGS3.
Solar portable charger absorbs the sun power and convert it into electricity. Solar portable battery charger the power bank by input cable. The power bank charges for the cell phone and other electronic products. I've never found any of these inexpensive solar chargers to be worth the trouble. In my knowledge, the only ones that really work are costly.
Thanking you!
Mobilesolarchargers
asnes
