[SOLVED]Stuck at sending system...
VSFe
4
I wanted to go stock rom, So I downloaded factory Image from google.
But, When send system partion, stop and not flashing.
I were waiting for 30 minutes, But, Not sending,
I tried with Nexus Root Kit, and flash-all.bat, but nothing work.
what can I do?
Sorry to my horrible english...
Flash Stock + Unroot...
erasing 'boot'...
OKAY [ 0.034s]
finished. total time: 0.034s
******** Did you mean to fastboot format this partition?
erasing 'cache'...
OKAY [ 0.106s]
finished. total time: 0.106s
erasing 'recovery'...
OKAY [ 0.035s]
finished. total time: 0.035s
erasing 'system'...
OKAY [ 0.117s]
finished. total time: 0.117s
erasing 'userdata'...
OKAY [ 5.003s]
finished. total time: 5.004s
sending 'bootloader' (3911 KB)...
OKAY [ 0.662s]
writing 'bootloader'...
FAILED (remote: (InvalidState))
finished. total time: 0.895s
rebooting into bootloader...
OKAY [ 0.020s]
finished. total time: 0.021s
sending 'radio' (16384 KB)...
OKAY [ 2.124s]
writing 'radio'...
OKAY [ 0.672s]
finished. total time: 2.797s
OKAY [ 0.020s]
finished. total time: 0.020s
archive does not contain 'boot.sig'
archive does not contain 'recovery.sig'
archive does not contain 'system.sig'
Bootloader Version...: 4.23
Baseband Version.....: 1231_0.18.0_0409
Serial Number........: 015d2a5045640411
checking product...
OKAY [ 0.040s]
checking version-bootloader...
OKAY [ 0.023s]
checking version-baseband...
OKAY [ 0.031s]
sending 'boot' (4992 KB)...
OKAY [ 0.674s]
writing 'boot'...
OKAY [ 0.208s]
sending 'recovery' (5532 KB)...
OKAY [ 0.738s]
writing 'recovery'...
OKAY [ 0.230s]
erasing 'system'...
OKAY [ 0.115s]
Re: Stuck at sending system...
Follow these steps -
1. Download image
2. Extract the image from the .zip
3. Place the extracted folder into platform tools which is located in the android SDK
4. Run flash-all.bat
Done.....
sent from my Nexus 7 using tapatalk pro..
P.s when using the nexus root toolkit make sure you tick the box under root to flash a custom recovery aswell :)
Hi, VSFe...
'sending system' seems to be a common problem... and one I've had myself many times.
Try changing to a different USB port on your PC... this usually fixes the problem for me. If not, try another USB cable.
Rgrds,
Ged.
Hi, VSFe...
Rgrds,
Ged.
Thank you! I used another cable, and problem was solved.
nafizahp3
