Sony Xperia Z1s Battery - WOW!
I have had the Xperia Z1s for about a few days now and I'm very happy with it. I hadn't planned on getting it since I was going to stick it out with my galaxy s4 for much longer, but the s4 had met an unfortunate end/accident. I must say, Sony's UI is a breath of fresh compared to Samsung's poor Touchjiz .
I love the battery life, that's key for my use. Since I'm in the jump program, I'll more than likely upg to thr z2 just because. Im never below 20% at the end of the night.
Sent from my C6916 using AC Forums mobile app
I'm jealous. My Xperia z1s battery lost exactly 20% within 68 minutes last night. My iPhone 5S had double the battery life. I would charge my iPhone while using it and it would be fully charged in about 90 minutes. I charge this Xperia z1s while using it and it takes about 5 hours to fully charge.
Weird, my z1s is suddenly developing poor battery life. Within the past month or so it's been draining on standby at a higher rate than before
I had the LG g2 and compared to the z1s I will say the g2 has a slight advantage battery seems to drain less faster, but not to take away from the z1s is.still last me a day power using plus some of the perks you get with a sony, I love both just wish this phone had more support.
check your battery usage in the power management section of the settings. It will tell you what seems to be consuming the largest amount of battery power. On my own Z1s, i have noticed that "google services" seems to be consuming a larger amount battery than it used to.
Stamina mode seems to have been broken. Now when I turn it on, it only shows about an hour or two of extra life, before it would add hours or even days
I would recommend a hard reset. Back up your phone first...
tuovst
