Soundgate M2 Phone Mount for Car
I love this thing.
I think the wipe took off some finish from my plastic trim, so use it lightly.
Mounted in a 2003 Pontiac Grand Prix.
I wanted to mount it to the left a bit but was concerned that it would interfere when I rotate it to take it out.
It feels like it should break but it is a rock. Once attached to your car, forget about moving it to another location. It's superglue to the max....
I need to make adjustments but I put the side piece over the hex screws....got to scuff it up a bit to remove the silver trim.
Best 15.00 I spen and it is so not bulky!
Ltcharensey
