Speaker problem please help
gatortuba
49
3
My speaker just stopped playing out for movies, apps and music.
They can only be heard from the headphones.
It still plays ringtones and speakerphone.
I uninstalled volume+ but that did not help.
Any ideas?
did that too.
Could something be making it think that a headphone is plugged in?
I don't think it does because anytime i plug in the headphones Google music starts.
Im lost past a factory reset.....i had that same problem with my first og droid. It thought i had a set of headphones plugged in after it got a little wet. It got stolen before i had a chance to remedy the problem so i cant tell you what i did......either way good luck brother. Ill be interested in seeing what happens.
I m having same problem aswell i did factory reset it did nt work aswell though i/ve noticed if i tap gently on the speaker it does works for a while but i guess i\ll send for warranty claim
Finally fixed it.
Something in the OS must have been corrupted.
I reset it to factory and still had the same problem.
So I used: "Wug's Galaxy Nexus Root Toolkit" to flash the original stock rom back over it and it now works.
Now I just need to set everything back up again.
ihtasham
