Spigen Neo Flex Screen protector
I couldn't stand it anymore. Peeled it off. Being naked feels so good
I'll give it a few days before deciding, one thing I am happy about is that the Samsung Rugged kick stand case fits ok without encroaching on to the Neo Flex.
Have an Olixar tempered glass on order but also ordered the Spigen Neo Flex screen and Neo Hybrid case already here so decided to install the Flex screen tonight.
I’m a fan of tempered glass from using them on my iPhone 6s and how optically clear and feels nice gliding your finger through glass but I’ll see how clear this one gets and how it feels with the pen. Maybe try the other tip if feels rough.
Installation was smooth and installed it in case just like the video above so I have it fit perfectly and no touch to the case. Like how it’s so thin almost not noticeable. I use screens more for scratch protection than drop protection. Will let it sit at home and cure for a day or two.
Threw on a s8 plus screen protector I had in the house and it fits perfectly on the note 8 with more room on the corners to avoid lifting
Took my neo flex off. Have the Whitestone dome that I hope to install today. The corners and sides of neo flex kept coming up with my tough armor case....
That's why I was glad I installed the screen while the phone was in the case... the film is cut pretty close to edges giving it a very good fit but can see it can give headache if off just a little for a case.
I installed while still in the case, but it still sucked.
Finally after letting the screen protector cure for couple of days and weekend is here can finally swap sims and play with phone...
First observation... use the white tip for the S-Pen with the Spigen screen protector. With the factory black, feels terrible and the tip is just dragging on the screen. The white brings back the smoothness and sensitivity even though not as smooth as gliding on bare glass of course.
Second observation... the screen is soft enough that using S-Pen will leave impression on the screen protector if you press heavy enough. It's kinda irritating to me but it seems to heal itself a bit and doesn't leave deep impression where you'll feel it when going over it with finger or S-Pen.
I like it for now but it's only been a couple of hours of play.
Have to add after using it for a couple of more days after the two day curing, it seems to me the surface feels much smoother to write on. I don't think it will be as smooth as glass with the gray tip but I do think it's getting better as the protector cures even further I guess.
tinni99
