Sprint 2.1 leak
I booted into the recovery menu did all the wipes(got errors for 2 of them). then i did the update.
Now the phone keeps rebooting itself.
I have no idea what to do. Please help?
Edit: I held down home button and turned on and now it looks updated!
adb devices - doesn't find the phone now and I'm having problems updating it in device manager.
Edit: I installed HTC sync 2.0.25 for the eris from HTC support site and now adb works agian.
Now to test...
Hey guys, can anyone help me out? I installed using the first option (when it was FIRST released yesterday morning) and most of my paid apps are not showing up in the market. Is there anyway I can switch back to DamageControl 2.1 or use the 2nd or 3rd options for this Sprint 2.1 leak?
http://forum.androidcentral.com/htc-hero-roms-hacks/9542-how-repair-your-bootloader-after-using-2-1-ruu.html
Try that. I have some class work I have to do for this upcomming week. I'll be on Google Talk though for anyone that needs help.
pharmerandy2010 AT gmail DOT com
Can someone tell me what version of wifi-tether to install now that I have 2.1?
1.6(HTC) works. In the first post is a link to some add-ons for this. You'll want to pick superuser and the wifi tether app that works is also on that page.
nice work gill this rom here is very responsive and smoother then the one i had.And everything works incliuding all of my paid apps form the market and free ones.But i have one problem.I had flipz rom, as you know i always geared to your rom, How can i get rid of the "flipz_01" in the pri version.Before you answer i did wipe and cleared cache and ext.:p
ok, it looks like i am in a bootloop using the second root method. i get the white HTC screen, but it will eventually go back to the sprint boot animation. i did a logcat and it eventually stopped after reporting: I/zygote < 993>: Exit zygote because system server <998> has terminated
it says some things after that to about media.this and that.
any help please?
any help please?
Did you wipe everything in recovery prior to flashing?
At least Data/factory reset, dalvik, and ext need to be wiped.
You're not gonna like this answer :)
RUU with the original 1.5 RUU
Update profile and prl
re-root, re-flash recovery, re-flash new ROM
Having said that, Flipz may have a solution. I'm not really sure what he did, but i was told that the above will get you back to the regular Sprint PRI.
any help please?
Are you using apps2sd?
Make sure you wipe everything. New ROMs from Sprint don't use odex files, so changing the system requires a full wipe (including the ext partition if you're using apps2sd). Also, anytime you change a file in /system, you need to wipe dalvik from recovery before you reboot.
ughh.... i thought about your solution,which i had in mind but i thought there's was a easier way...:o
thanks buddy..:)
i did. then i went in there and messed with contacts. i am guessing that is where i messed it up.
soooo i went and just installed the ruu from windows cause i am impatient and wanted to play with 2.1. used that for a litttle bit at dinner but started to get constant force close due to process.gapps.
now i am restoring my backups and i am gonna try the root method again. and this time i won't fiddle with anything after i do a wipe.
i will report back.
ok. the root method worked this time. didn't mess with anything after the wipe. just immediately installed the .zip.
where do i get the busybox and the super thing? i am an idiot and can't find it.
First page it says add-ons click the link should be some zips that you flash threw recovery.
silly question, but how do I install the 2.1? I did all the rooting and nandroid backup stuff in the other How-To guide, but I'm not sure what to do here. Do I copy the signed-cl157175.zip to my sd card?
Annuji202
