Sprint 2.1 leak
Honestly I would guess because the hero just couldn't handle live papers. They were made for a much more powerful phones in mind. The heros hardware us aging at best.
I flashed with option one and everything is working perfectly on my phone. If you are having trouble check the post on how to repair your bootloader. It only takes a few minutes to fix and then you can reflash the 1.5 recovery back and start over.
I will try. Thanks to everyone providing me some hope.
LiveWallpapers with Sense
All thanks goes to zenulator and mssmision on XDA for this. All i did was download his rom and make a zip to get this to work. There is two zips you have to flash to get it to work. YOU WILL LOSE WEATHER ANIMATION.. For them to stick. Copy both zips to sdcard,boot into recovery, flash zip 1 then zip 2. Then reboot. NexusMod livewallpaper(free in market) works great. Should do a nadroid backup just incase you don't like or something goes wrong.
Zip 1-- Moved,look in the mods and add-ons thread.
Zip 2--Moved,look in the mods and add-ons thread.
I put together a zip for the clear lockbar.Always do a nadroid back up before just incase something goes crazy.
ClearLockBar.zip
Ok I installed this but I dont care for it. I thought it would be "ghost" colored or transparent with some kind of outline like window borders in vista. Instead its just plain gone with only the date floating there. Thought it was cool anyway until I got a phone call and realized my answer slider was gone too. Yes I know its still there only invisible but I wanted clear not invisible.
Is there a way to get rid of this without doing a nandroid restore?
Yeah i'll make a zip to change it back.
So Gbhil, are you running Gumbo Unleashed or what?
I'm running a little something different. A little newer than this leak, and is supposed to address some bugs I've never seen in the framework.
As things progress, and if it doesn't introduce more or bigger bugs, I'll incorporate all patches into option 3 from the first post.
I'm sure most people at Sprint or HTC either hate us (people with hacked Hero's), or don't care, but there is at least one person that understands that we will install leaks because of the long wait for 2.1 and is sympathetic. I'll bet he/she used a Blackberry at one time :D
Lots of nice work here chief!
You should start you own thread, that shows off your work so it doesn't stay hidden 15 pages deep here
Thanks just doing my part to help out where i can. I was just thinking i should start a thread..lol I'm going to get a couple more things together then i will.;)
Sounds great. I'm only going to focus on what we're calling option 3, so the things like what you're doing will let people build their own custom ROM.
I have to get caught up on some things I didn't get done while I was crying about my headache, but I plan on "enhancing" option 3 with some fixes from upstream and the community. Hopefully some time this week.
cool anxiously waiting...lol i prefer custom rom anyways i think i wont be updating whenever sprint decide to update the hero, I'm fine with what you already put out..
okay i go to wallpapers and i see them there and they work but when i set it to be a wallpaper it dont appear to work??
The included live wallpapers are for the nexus one only. Try some from the market, I recommend plasma.
The maps wallpaper should work as well.
Ok...
I frequently lose all sounds on my phone now, rendering the phone unusable. Three times out of five the phone resets itself.
Would switching from option 2 to 3 possibly fix this? And is it possible to do?
Abheetha Athukorala
