Sprint 4G - Most speedtest apps don't work well, how to confirm max speed
xorg
351
6
Do not use the Speedtest or FCC app from Market. They are seriously flawed for 4G tests for most servers. Those say only 1.5Mbps for most tests at my location but are significantly off as I can demonstrate sustained 7Mbps with 3 other methods.
Use Dolphin HD browser, is more faster for me. Might try plugging in headphone to act as antenna. FM radio uses headphones for antenna, 4G radio might also, not sure.
This site seems to work better but it depends. It's really odd the speedtest sites don't stress 4G well but work fine with WiFi. Also post how many 4G bars you have.
Speakeasy - Speed Test
Also test using the 4G Hotspot, which is free at the moment. Was able to stream Netflix HD with no rebuffering.
My highest so far using Chicago test site. Note only 2 4G bars.
I was skeptical that speedtest.net only shows spikes, not sustained rates, so did a stress test.
Have stressed the 4G connection with several streams simultaneously. Used Wireless Tether app, which shows bit rate of connection while pumping a bunch of data streams at once. Downloaded three 100MB+ files at once and did Netflix streaming on a PC connected to EVO hotspot.
I was indeed able to SUSTAIN about 7Mbps. Netflix streaming BTW kept ticking with no rebuffering. I'm seriously thinking of setting up a Buffalo router as a repeater and getting rid of my 7Mbps cable modem.
Still wasn't convinced. I used another tool to verify looking at the WiFi layer in tether mode while doing the same stress test above. The Network Monitor app shows in Bytes/sec so need to multiple by 8 to get bits. It says 1140KBytes/sec, which is >9Mbits/sec. Factoring overhead, it's safe to says it's >7Mbps and it was sustained for duration of the downloads.
I tested again with the Speedtest app from Market and it said I only get 1.5Mbps. There is something very wrong with that app for 4G tests.
Also note that newer Cleawire markets have 30-40Mbps microwave backhaul and/or up to 100Mbps wired backhaul to each site. Early Clearwire markets started with much lower backhaul, so you may get lower results depending on load due to other users. Will take a while to upgrade older sites with more backhaul. Give it time.
Backhaul options diverse for 4G networks - RCR Wireless News
http://forum.androidcentral.com/carriers/14025-wimax-4g-porn-kansas-city.html#post125204
Maxyguy666
