Sprint Samsung Galaxy S4 - Official Android 4.3 Update Discussion
Just got mine today, not sure what took so long but oh well.
First change I see is 4G now indicates 4GLTE in the notifications panel. Next change I see is in my contacts.
Sent from a device beyond your wildest dreams!
What do you see different in your contacts
Sent from my SPH-L720 using AC Forums mobile app
Woohoo!!! :thumbup::thumbup::thumbup:
Finally!!! :thumbup::D:thumbup::cool:
Sent From Inside The TARDIS in a Galaxy S4 Away!
I see the 3G icon is also different and bigger. :D
And now there's a "Reading Mode" instead of the mobile data toggle. :banghead:
Is anyone missing the KNOX icon and Gear icon? After update I don't have either one. When I look in Application Manager I can see they are loaded...but I can't open them!? Is that normal? One of my buddies has the Verizon Galaxy S4 and he said he has icons for both.
When it rebooted after the install...there were two new icons on my home screen (they were actually on top of existing icons which I thought was weird). They were the Dolphin Browser icon and something called Get Apps. I already had Dolphin installed before this update so I think something got screwed up...unless Samsung is bundling Dolphin with its updates now. Help!
Yeah I can't believe they took that away. Now you have to go through settings just to turn it off :(
That sucks! 😠😲
Yeah, it seems very strange that they would remove the Mobile Data button. I downloaded a app/widget to turn the mobile data on and off, and so far it seems to be working properly. It's at least easier than going into the settings. I tested it by turning it on from the widget, then going to see if data was on in the settings (it was), then I turned it off from the widget and noticed it was off in the settings.
Are the "A-Z" letters on the right side of the Contacts screen smaller? Maybe it's just my imagination, lol. I am having a heck of a time selecting the right letter (I end up clicking a contact instead), and my fingers aren't even that big. I mean, I've always had a hard time, it just seems worse now
Na, they're the same size...
Without a case or with the S-View Flip Covert I can press on a letter easily.
With the case I use for work is not easy. 😞
Do you have knox or gear on your phone after update?On mines it doesn't show.
I only see them in the app manager.
Crghjuygf
