Sprint's LG G2: Tri-Band LTE aka SPRINT SPARK
Re: Sprint's LG G2: Tri-Band LTE aka Sprint Spark
Can you use this file to update the phone?
Wait for the update to hit someone's phone, then they will either post the update link to Google's server or the update zip itself.
You can then take the file yourself and apply the update. As long as you haven't modified any system files, it will pass and update everything. It's like forcing the OTA early.
Thanks to digiblur.
Mav. :cool:
Specifically, this is the open source code used to build the binaries that are then used to update the phone. There may be additional non-open bits that will be part of the update. But seeing this posted means the official update is complete and awaiting staging and roll-out from Sprint. Since this update enables "Spark," there may also be network configurations that are needed before Sprint wants to go live.
Thanks to digiblur.
Mav. :cool:
would I need to be rooted to run this?
Just got my spark update.... Let's see what kind of battery life i get today
Posted from my Lg G2 over Sprint in Orlando
Got my update
Had to clear my Google Service Framework
Downloaded and updated
Added a new boot up screen
Did it just show up or did you go to an update screen and check?
I wonder if the fact that I manually enabled tri band on my device is causing update issues.
Re: Sprint's LG G2: Tri-Band LTE aka Sprint Spark-Update released.
I changed the bands before the update but with the update do the priorities change or to they stay the same??
Does anyone have the download link yet?
r3dpuk3
