Stable One UI 5
BVJA (Android 13, One UI 5.0) is out now for US unlocked S22Us (U1 models), and is downloadable via Frija if you don't have it OTA yet.
Got it this morning for AT&T unlocked. Oddly, all the app icons in my notification panel are now just white circles after applying. Rebooted, no help there. Anyone know a fix for this?
I got it this morning on unlocked using Tmo. Nothing looks wise has changed for me. Custom wallpapers and icons are still as it was before update. Hope you find a fix
Removing my themepark theme fixed it. reapplying it, the icons are still white circles but now have an icon overlaid? So perhaps this is some new setting my old themes didn't have data for. At some point I'll create a new theme, see what it does. So for anyone else, that's what worked for me. S22+ Unlocked
Just downloaded last night and now my device is snapier and very quick. No issues with the last beta final update. Android 13 is great so far.
Sent from my SM-S908U using Tapatalk
downloading on tmo unlocked. my wifi is on 56k speeds for some reason...lol
Received update on my Unlocked s22U running on T-Mobile.
Google Play became 'stuck'. Had to force stop Play & Services, clear the cache & reboot into recovery to clear the cache partition. It seems to be okay now.
My experience has been great my device is faster and very snappy.
Mine has serious lag. Opening and closing any app takes about 3-5 second to load or close. I've done all the simple fixes but no change. I think I'm going to have to prepare for an FDR. Which is what I used to always do before a major update anyway.
Sent from my SM-S908U using AC Forums mobile app
You did cache clean in recovery? Try also in recovery repair apps
Screwgoogle
