Re: starting may 27th grandfathered plans will no longer be perma
You guys are a bit ridiculous.
You say $35 isn't worth it, but have you really investigated the options? I have been for the last 6+ months. Why do you think I use an Evo on Virgin.
T-Mobile is probably the best and only real alternative, for me at least. Yeah you get 4g, but once you exceed your limit you get 2g, not 3g. Also, coverage can also be an issue, for me, T-mobile data coverage is pretty much NILL in my neighborhood, while I get decent rates from Sprint. I would also have to do the 2gig plan and hop I don;t go over, otherwise, the 5gig plan, my monthly bill would be $45-50 a month after extra phone fees since 100 minutes is a joke.
As for Straight Talk and such, you REALLY need to read the fine print (and other forums) on those. Some of their "3g" speeds are throttled worse than Virgin. One was throttled at 119k MAX, for 3g, to go faster you need the $60 "4g" plan which gives you 3g speeds. Others with faster speeds have 500meg or 1gig limits, others will nail you for simply using 100megs in a single day, regardless of monthly use. Some of those MVNO's are simply terrible. Be very careful before you go spending your money on them.
Granted it depends on how many minutes you need, but the bottom line is that $35 isn't bad for what you are/will be getting, don't fool yourself. Yes, the increase sucks, but think things through and research before you go off in a huff and blow $200-$300 on a phone.
No, because you will need a new phone to get 4g, which moves you to $35
You will NOT get 4g on the $25 plan unless VM drops a 4g phone before the increase, which is HIGHLY unlikely. Possible, but unlikely. I think a few snuck in under the wire on the Triumph.
I wonder if the 4g data would be available on the 25 dollar plan. They would possibly just switch 4g on all plans since you would have to buy a new phone to access the data anyhow.
