Straight Talk apn settings for AT&T Samsung Galaxy S3
Re: Straight talk apn settings for at&t samsung galaxy s3
at&t s3 i747 This is what worked for me.
APN: tfdata
Proxy: Not set
Port: 80
Username: Not set
Password: Not set
Server: Not set
MMSC: http://mms-tf.net
MMS proxy: 66.209.11.33
MMS port: 80
MCC: 310
MNC: 410
Authentication Type: PAP
APN type: default,supl,mms,hipri
APN protocol: IPv4 (can't edit)
Enable/disable APN: box checked (can't edit)
Bearer: Unspecified
I have an uloacked samsung galaxy S3 on branded AT&T. Went through all 5 pages, tried every APN on here. This is the only one that allowed me to send/receive MMS and still have everything else work right.
that apn worked on my phone. although i said it woudnt work but my network is connected. now time to enjoy this phone.
hey everyone its currently 1:12am march 20th 2014, I reset my phone today ( GALAXY SIII mini) (at&t - StraightTalk) and like everyone ells on here I had issues reactivating my APN settings!
well after reading thro this blog and trying different sequences I finally typed in this one restarted my phone after saving and instantly was greeted with 4g LTE.
APN: tfdata
Proxy: mms3.tracfone.com
Port: 80
Username: Not set
Password: Not set
Server: Not set
MMS proxy: mms3.tracfone.com
MMS port: 80
MCC: 310
MNC: 410
Authentication Type: PAP or CHAP
APN type: Not set
Bearer: Unspecified
The easiest way is to download the Straight Talk APN app. Its fast and easy!!
APN: tfdata
Port: 80
Username: Not set
Password: Not set
Server: Not set
MMS port: 80
MCC: 310
MNC: 410
APN type: Not set
Bearer: Unspecified
Thank you thank you thank you! Worked for my Motorola tx907 using the att sim!
you might want to fill in APN type: default,supl,mms,internet,hipri. I have an unlock Galaxy S3. My data and mms was never work until I added these APN type setting. I hope this help everyone =D
I am about to change from iPhone 4 to Samsung Galaxy S3. I have my iphone 4 on Straight Talk and had these same issues for about 2 months. Then one day I found a setting on Apples forums that worked, and it even gave me a notice that said "New Network settings available. Download Now?" If you get this, say yes. Otherwise your phone wont work. Now, here is my question for you. When I get the Galaxy, can I simply take my SIM card out of the iPhone and put it in the Galaxy, then change the settings and everything will work. Or must I call ST to have them program the phone still?
So here's my issue now, it seems like I can get texts and MMS from Android phones but not iPhones. Strange. Any help? Here are my settings right now:
APN: tfdata
Proxy: Not Set
Port: Not Set
Username: Not Set
Password: Not Set
Server: Not Set
MMS Proxy: mms3.tracfone.com
MMS Port: 80
MCC: 310
MNC: 410
APN Type: default,supl,mms,admin,fota,hipri
APN: tfdata
Proxy: Not Set
Port: Not Set
Username: Not Set
Password: Not Set
Server: Not Set
MMS Port: 80
MCC: 310
MNC: 410
Final update. Seems like everything is working now. I can send and receive both SMS and MMS to all users. Word of note, Straight Talk told me to make sure the iPhone user has iMessage turned off and that they are using all 10 digits of my phone number when texting me. Tested and worked. Here are my final working settings:
APN: tfdata
Proxy: Not Set
Port: Not Set
Username: Not Set
Password: Not Set
Server: Not Set
MMS Port: 80
MCC: 310
MNC: 410
APN Type: default,mms,supl,hipri
Make sure APN Type is entered exactly as I typed it, with no spaces after the commas. Good luck.
APN: tfdata
Proxy: Not Set
Port: Not Set
Username: Not Set
Password: Not Set
Server: Not Set
MMS Port: 80
MCC: 310
MNC: 410
This isn't working for me. Not sure why...
Sorry , it did work for me. I had to set up a new APN and de-select ATT . So grateful for the above info. Hope you get yours !
Awesome!!! I had one **** of a time with this. Your settings worked perfectly. Thank you for making this so much easier for me than calling Straight Talk.
ok people, there is only 1 answer............download the straight talk apn settings app from the play store!!! I was on here reading and changing apn settings, forever. Downloaded this app, i am getting pics now and took me maybe, 5 mins!! its just that easy. i am using unlocked att samsung galaxy s3 converted to straight talk w/sim. I do beleive one of the app comments was it didnt work if your phone did not have sim, but i would try it anyways, maybe they have updated it, it is free!!
APN: tfdata
Proxy: Not set
Port: 80
Username: Not set
Password: Not set
Server: Not set
MMS port: 80
MCC: 310
MNC: 410
Bearer: Unspecified
This worked for my Android Mini N900. Thank you so much. Straight Talk kept giving me the wrong settings. Did it on my own (with your help too) and feel amazing :)! Only thing is, For APN type: default, supl, mms, and wap. Didn't have hipri.
Tfunz
