Strange Haptic Feedback
What is your setting here?
I dont think Mike mess with accessibility settings
By the way you still haven't verify what have you tried ???????
Like pulling teeth
Ok Mike , I tried this with all sounds enabled, no issues , so I suggest you clear data,cache, and force stop keyboard first and recheck if still happens gmail next ..let me know
Are you using the stock keyboard?? If so try a third party and see if it has the same feedback with another keyboard.
Issue solved and it's actually not the keyboard. I figured it out, It's the touch interactions. I just don't normally notice it because I usually have system volume down. If you click it precisely in extreme left it's one tick. If you click it elsewhere in address line you get multiple clicks. I just turned it off and I'm good to go.Screenshot_20200304-232011_Settings.jpeg
Issue solved and it's actually not the keyboard. I figured it out, It's the touch interactions. I just don't normally notice it because I usually have system volume down. If you click it precisely in extreme left it's one tick. If you click it elsewhere in address line you get multiple clicks. I just turned it off and I'm good to go.View attachment 317413
You owe me dinner...
libraz52
