SwiftKey Flow is now out of beta!
Re: Flow [UPDATE]
That was a long wait, I'm sure it will have fantastic performance, even in "beta" form. Less than 18 hours left now...
Re: Flow [UPDATE]
Got my Swiftkey flow working on my Nexus 4 and Nexus 7.
Using it to type this message right now. So far I wish the swipe having animation was more prominent/visible. It make it easier to track...
Sent from my Nexus 4
Re: Flow [UPDATE]
You can't swipe to erase the last word with flow enabled. Not a big issue but will need a little being used to.
Re: Flow [UPDATE]
Not sure I like it better than swype but it seems to work pretty well. This is going to take some use
Sent from my SCH-I535 using Android Central Forums
Re: Flow [UPDATE]
It seems to work okay, but when ever your at at a login field, flow isn't enabled. I must admit, I thought the experience would be a bit better but the prediction is very good
Re: Flow [UPDATE]
It does take some getting used to holding delete to get rid of the last word. Well not if you're a swype user anyway.
I'm gonna look and see if I can change the color of the "trail", not a fan of the rainbow.
Re: Flow [UPDATE]
Can't wait to get home and download it.
Sent from my EVO using Android Central Forums
Re: Flow Beta now avaliable
Downloaded and using on my Gnex. I love it so far.
Best of both worlds. Swype/SwiftKey :-D
I've been trying to complete the installation but it won't download the language it says no connection but I have connection
Sent from my ADR6425LVW using Android Central Forums
Same here.they're servers must be getting hammered.
Yea I think that's it I just tried again and it worked I'm using it now
Took me about 4 attempts to get the language pack downloaded.
Downloaded from the email they sent me. It won't download English . Am I missing something? Anyone else having this issue? EDIT,, I others are having this problem. I should have read first..
EVO-LUTION 4G LTE
EVO-LUTION 4G LTE
They had a tweet I saw, that said since so many people are downloading it their language servers are having trouble. Just keep trying until it works for you.
I just tried again and it downloaded. Thanks.. Keep trying people,, it will work. ;)
EVO-LUTION 4G LTE
When I download the tablet version from the website it doesn't allow me to press install. Has anyone else encountered this?
Michael Carvalho
