Swiping problem after replacing cracked screen Nexus 5
marplasto
I replaced cracked screen, all functionality works fine, but when I swipe (instead of typing letter by letter) phone is not working as well as before (e.g. some words get predicted wrongly and sometimes several letters get typed in when not intended). Is this a loose connection or maybe the OEM screen replacement is not as sensitive as the original Nexus 5 product ? I can open up again but I need to know what I am looking for. Thanks guyz !
Welcome to Android Central!
It could be that the replacement screen you put on is just not as sensitive ad the one you had before. Sometimes they are a little cheap and do not work as well. There is an app you can try to modify the screen sensitivity on the software side. It might help out a little bit.
https://forums.androidcentral.com/e...s.touchscreenbooster.com&hl=en&token=xdNjdK6C
shaik
