Font Change How To; basic
You must be rooted and have Clockwork, and ROM manager installed to use this method. There are instructions using adb in the xda link below.
http://forum.xda-developers.com/showthread.php?t=801160
Select the font you choose to down load from the desired link.
Please note that you should look at the screen shot closely. Some fonts look cool but when they are on your phone they can be so large or ornate that they can make it difficult to read.
FYI: If you use the notepad some of the fonts make it so the words do not line up on the lines.. This will also affect the way some other displays of text are displayed.
I would suggest that you download the desired font packs to a folder (I named mine ‘Fonts’)
Then copied the entire folder to the sd card on the phone when I was ready.
When ready to load (flash) the new font. Boot into Clockwork Recovery via ROM Manager.
Use the volume up/down to negotiate the menus in Clockwork Recovery. The back <- arrow selects you desired item.
You will want to ‘install a zip from sd card’.
Negotiate your way (using the volume rocker and the back soft key) to the file folder named ‘Fonts’ then select the desired font pack you wish to install.
Once you have selected it you will have to negotiate your way through a lot of ‘no’ options to the yes- option to install the font pack (zip file).
It will process the pack to the correct directory on the phone. Clockwork will return you to the last menu that you used and you will have to negotiate your way back to the main menu where you will want to reboot the phone.
Note: If you are not attentive to the menu you can navigate your way to clearing cache, wiping the phone or installing the update.. You have to pay attention to where you are going.
Keep in mind that this is a system font and you will see it EVERYWHERE (SMS, emails, popup notifications, submenus etc.. in all programs It will replace the numbers on your calculator… except the dial pad numbers.
Hope this helps…. Happy flashing
