T-Mo Note 8 Oreo
Status
Not open for further replies.
Here're the release notes:
Took a couple tries to down load as it kept saying unable to connect to server. Finally connected. All set.
I don't know if it's just from being rebooted. But my iris sensor seems to be a bit quicker at unlocking than before.
I've noticed a significant improvement in iris sensor speed on the leaked builds that I've been using
Yep. Guess they meant midnight when they said Sunday night. Ready to install mine now as well.
In-process now.
The "Installing Android" portion that occurs after restart will probably take an hour, given the time it's taken to do just 30% of it. Haven't seen this before with previous updates.
Took maybe 10 minutes.. definitely faster than my iOS devices when they are being updated haha.
Thanks. But I was thinking since this took over a gig of memory after the download will I get that back when this gets done updating?
My LTE reception was pretty good prior to update... After the update, it's like it reception on steroids!
Tmonike got Oreo finally!
Got mine last night
Do you remember tweaking the colors in the past and possibly the update just reset it back to factory default?
Good question, as I have not seen anyone else with that specific problem after updating.
No I have never made any changes to the display settings. I think I fixed it though. I reset the device and set it up as a new phone instead of from Google or Samsung backup.
Status
rose1988
