T-Mobile LG G3 5.0.1 3/31 LGMobile Support Tool
After I did the upgrade I noticed I cant screen shot by swiping and saving to quick memo , I can never get it by pressing the volume down arrow and the power button at the same time so swiping was easier for me. Any suggestions???
You can swipe down from the notification bar and select quick memo+ to do a screen shot
LG G2 is a go, but i keep getting check out the model and serial number someone please help im about to return my lg g3, never got the update :'(
I downloaded the Lollipop update and everything seems to be working fine overall. I just can't get rid of the My Tmobile Account widget on my lock screen. Anyone have similar problems and figure out a solution? Or have an idea of what to do?
You can get rid of it within the settings of the actual tmobile app.
Nazeer zaheen
